简介
我们上一次拆解的 LG 手机是非常模块化的 LG G5,它很容易拆开并在我们的可修复性仪表盘里得到了 6/10.但是时光飞逝——我们现在有什么呢?让我们来拆开全新的 LG G7 ThinQ 吧。
你所需要的
视频概述
由衷感谢以下译者:
en zh
100%
Patrick Zhang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
9条评论
Good luck to you.
coco - 回复
哈哈哈哈哈哈哈哈哈哈哈哈
coco - 回复
wanted close up pictures
Genesis Amadeus - 回复
when the back glass cover is replaced after it is cracked and then pried off, how do you achieve “water proof” again”? Thank you
Richard W - 回复
You have to install new adhesive.
segin2005 -
little gotcha - the replacement kit did NOT come with the side buttons. sadly i moved everything out of the old case into the new case before realizing this, and had to disassemble again. to get your old buttons out, pull up the enclosing black tabs on the sides, pry up the silver stuff with a guitar pick, and push them out from inside (careful or they will go flying). then replace those parts into the new case… working on it right now :D
jinglesboiler - 回复
I change front pannel and now wifi and gsm signals are very weak like i sit besides router signal show 3 bars.. What should i do. And from where i can find a new heat pipe for lg g7
Salma Saad - 回复
what type of adhesive is required to attach the back glass and reseal for IP rating?
Fritz - 回复
I have signal issue with my lg 7 some time comes some time it's very hard no service issue mostly when I am traveling
sardar toqeer - 回复
