跳转到主内容
你所需要的
视频概述
这个拆解是不是维修指南。 要维修你的的LG G7 Thin Q,请使用我们的维修手册
    最后的想法
    • 很多的部件是模块化而且可被单独更换。
    • 电池可以更换但是有胶水并粘在了后盖上,这带来了不必要的困难。
    • 前后玻璃面板带来了双倍的易损,强力的粘合剂两面都有,使得进入内部维修很困难。
    • 屏幕维修时最常见的维修类型,却没有最优先考虑,需要在和强力粘合剂战斗的同时几乎完全拆解手机。
    可修复性评分
    4
    可修复性10分中得4分
    (10是最容易修复)
由衷感谢以下译者:
en zh
100%
Patrick Zhang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
9条评论
Good luck to you.
coco - 回复
哈哈哈哈哈哈哈哈哈哈哈哈
coco - 回复
wanted close up pictures
Genesis Amadeus - 回复
when the back glass cover is replaced after it is cracked and then pried off, how do you achieve “water proof” again”? Thank you
Richard W - 回复
You have to install new adhesive.
segin2005 -
little gotcha - the replacement kit did NOT come with the side buttons. sadly i moved everything out of the old case into the new case before realizing this, and had to disassemble again. to get your old buttons out, pull up the enclosing black tabs on the sides, pry up the silver stuff with a guitar pick, and push them out from inside (careful or they will go flying). then replace those parts into the new case… working on it right now :D
jinglesboiler - 回复
I change front pannel and now wifi and gsm signals are very weak like i sit besides router signal show 3 bars.. What should i do. And from where i can find a new heat pipe for lg g7
Salma Saad - 回复
what type of adhesive is required to attach the back glass and reseal for IP rating?
Fritz - 回复
I have signal issue with my lg 7 some time comes some time it's very hard no service issue mostly when I am traveling
sardar toqeer - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 127
总计 43,709
