跳转到主内容
LG G7 Thin Q Back Cover Replacement
你所需要的
  1. LG G7 Thin Q Back Cover Replacement, SIM Card: 步骤 1 中的图像 1,1
    • Insert a SIM card eject tool into the hole in the SIM card slot on the top right of the phone.
    • After the SIM card tray is ejected, remove the SIM card tray from the phone.
    • Remove the SIM card from the tray.
  2. LG G7 Thin Q Back Cover Replacement, Back Cover: 步骤 2 中的图像 1,1
    • Place the phone so the back cover is facing upwards.
    • Insert the opening picks one by one onto each side with equal pressure.
    • There is extra adhesive at the top near the cameras. You need to loosen the adhesive there to open the case.
    • If the picks are too thick to fit in, you can use the Jimmy to start the process.
    • Use the pick with the best leverage to pry the back cover away from the phone.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 54
总计 2,078
