跳转到主内容
LG G6 USB-C Port Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. LG G6 USB-C Port Replacement, iOpener Heating: 步骤 1 中的图像 1,2 LG G6 USB-C Port Replacement, iOpener Heating: 步骤 1 中的图像 2,2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. LG G6 USB-C Port Replacement: 步骤 2 中的图像 1,1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. LG G6 USB-C Port Replacement: 步骤 3 中的图像 1,1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. LG G6 USB-C Port Replacement, Alternate iOpener heating method: 步骤 4 中的图像 1,2 LG G6 USB-C Port Replacement, Alternate iOpener heating method: 步骤 4 中的图像 2,2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. LG G6 USB-C Port Replacement, Battery: 步骤 5 中的图像 1,1
    • Apply the heated iOpener to the edge of the phone for about 2 minutes.
  6. LG G6 USB-C Port Replacement: 步骤 6 中的图像 1,3 LG G6 USB-C Port Replacement: 步骤 6 中的图像 2,3 LG G6 USB-C Port Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
    • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
    • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
  7. LG G6 USB-C Port Replacement: 步骤 7 中的图像 1,2 LG G6 USB-C Port Replacement: 步骤 7 中的图像 2,2
    • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
  8. LG G6 USB-C Port Replacement: 步骤 8 中的图像 1,2 LG G6 USB-C Port Replacement: 步骤 8 中的图像 2,2
    • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
  9. LG G6 USB-C Port Replacement: 步骤 9 中的图像 1,1
    • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
  10. LG G6 USB-C Port Replacement: 步骤 10 中的图像 1,3 LG G6 USB-C Port Replacement: 步骤 10 中的图像 2,3 LG G6 USB-C Port Replacement: 步骤 10 中的图像 3,3
    • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
    • Do not use a knife as you may pierce the battery.
  11. LG G6 USB-C Port Replacement, Motherboard: 步骤 11 中的图像 1,2 LG G6 USB-C Port Replacement, Motherboard: 步骤 11 中的图像 2,2
    • Locate the sim card tray release mechanism on the right edge.
    • Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
  12. LG G6 USB-C Port Replacement: 步骤 12 中的图像 1,3 LG G6 USB-C Port Replacement: 步骤 12 中的图像 2,3 LG G6 USB-C Port Replacement: 步骤 12 中的图像 3,3
    • Gently pry off the two connectors at the bottom of the phone.
    • Pry off the tape covering the vibrator.
  13. LG G6 USB-C Port Replacement: 步骤 13 中的图像 1,2 LG G6 USB-C Port Replacement: 步骤 13 中的图像 2,2
    • The motherboard is now removable by gently lifting.
    • Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
  14. LG G6 USB-C Port Replacement, USB-C Port: 步骤 14 中的图像 1,2 LG G6 USB-C Port Replacement, USB-C Port: 步骤 14 中的图像 2,2
    • Gently pry the USB-c port assembly out of the frame.
结论
8等其他人完成本指南。
David Pugliese
于09/26/17注册
1,156 声望
创作了4篇指南
团队
USF Tampa, Team S2-G6, Passmore Fall 2017 USF Tampa, Team S2-G6, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S2G6
4 名成员
创作了11篇指南
2条评论
what size tape did you use?
Miguel “CharlieMike” Dias - 回复
I skipped removing the main board and was able to remove the port by just lifting the PCB up a little. I also did not remove the battery. just disconnected it. was able the slide out and in the USB port with no trouble or damage.
tenchi50 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 9,242
