跳转到主内容
加入维修社区 - 创建账户
LG G5 Rear Camera Replacement
你所需要的
  1. LG G5 Rear Camera Replacement, Front Panel Assembly: 步骤 1 中的图像 1,2 LG G5 Rear Camera Replacement, Front Panel Assembly: 步骤 1 中的图像 2,2
    • While holding the battery release button, pull the bottom end of the phone out of the body.
    询问修复机器人
    添加评论
  2. LG G5 Rear Camera Replacement: 步骤 2 中的图像 1,3 LG G5 Rear Camera Replacement: 步骤 2 中的图像 2,3 LG G5 Rear Camera Replacement: 步骤 2 中的图像 3,3
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
    询问修复机器人
    添加评论
  3. LG G5 Rear Camera Replacement: 步骤 3 中的图像 1,2 LG G5 Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
    询问修复机器人
    添加评论
  4. LG G5 Rear Camera Replacement: 步骤 4 中的图像 1,1
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
    添加评论
  5. LG G5 Rear Camera Replacement: 步骤 5 中的图像 1,2 LG G5 Rear Camera Replacement: 步骤 5 中的图像 2,2
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
    添加评论
  6. LG G5 Rear Camera Replacement: 步骤 6 中的图像 1,2 LG G5 Rear Camera Replacement: 步骤 6 中的图像 2,2
    • Peel the screen away from the body. The two parts should be completely separated.
    询问修复机器人
    添加评论
  7. LG G5 Rear Camera Replacement, Rear Camera: 步骤 7 中的图像 1,3 LG G5 Rear Camera Replacement, Rear Camera: 步骤 7 中的图像 2,3 LG G5 Rear Camera Replacement, Rear Camera: 步骤 7 中的图像 3,3
    • Insert the plastic opening tool between the camera-ribbon connector and the motherboard, then pull up. It should pop out easily.
    询问修复机器人
    添加评论
  8. LG G5 Rear Camera Replacement: 步骤 8 中的图像 1,2 LG G5 Rear Camera Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • After detaching the ribbon, carefully remove the camera using tweezers
    添加评论
结论
取消:我没有完成这个指南。
34等其他人完成本指南。
团队
Cal Poly, Team 18-2, Forte Fall 2016 Cal Poly, Team 18-2, Forte Fall 2016 的会员
CPSU-FORTE-F16S18G2
4 名成员
创作了15篇指南
6指南评论
This worked great and took me about 10 minutes!
Mark - 回复 分享
Great instructions. This was my first time taking apart any phone. Everything went smoothly and my camera now works! thank you
Christopher Piatt - 回复 分享
the camera is held down with sticky tape and I wasn’t comfortable pulling hard under the processing board, so I pulled the six screws holding that down and removed it first. Unfortunately for me the new camera still doesn’t focus…
Ray White - 回复 分享
This worked great for me. I was a little nervous prying on my phone, especially when I heard the first POP. But after that, it was not hard at all. The new camera focuses great for me now and I can get back to taking great pictures with my G5!
Thanks for the detailed instructions, tools and affordable part!
Brad - 回复 分享
You may want to mention that the original camera is glued in. It takes a bit of prying to pop it out.
Ryan - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 39
总计 18,046
