跳转到主内容
LG G5 Front Panel Assembly
你所需要的
  1. LG G5 Front Panel Assembly, Front Panel Assembly: 步骤 1 中的图像 1,2 LG G5 Front Panel Assembly, Front Panel Assembly: 步骤 1 中的图像 2,2
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Front Panel Assembly: 步骤 2 中的图像 1,3 LG G5 Front Panel Assembly: 步骤 2 中的图像 2,3 LG G5 Front Panel Assembly: 步骤 2 中的图像 3,3
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Front Panel Assembly: 步骤 3 中的图像 1,2 LG G5 Front Panel Assembly: 步骤 3 中的图像 2,2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Front Panel Assembly: 步骤 4 中的图像 1,1
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
  5. LG G5 Front Panel Assembly: 步骤 5 中的图像 1,2 LG G5 Front Panel Assembly: 步骤 5 中的图像 2,2
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
  6. LG G5 Front Panel Assembly: 步骤 6 中的图像 1,2 LG G5 Front Panel Assembly: 步骤 6 中的图像 2,2
    • Peel the screen away from the body. The two parts should be completely separated.
结论
Now you can access all the inner components of the phone!
32等其他人完成本指南。
团队
Cal Poly, Team 18-2, Forte Fall 2016 Cal Poly, Team 18-2, Forte Fall 2016 的会员
CPSU-FORTE-F16S18G2
4 名成员
创作了15篇指南
4条评论
quickest 50 bucks i ever made, lol. Thanks for having the guide up.
Montez Hardnett - 回复
Love this phone... So MODULAR! Thanks for the guide.. Had to double-check when I was pulling it apart.. almost seemed too easy.
Christopher Williams - 回复
Wow, I didn't realise this phone was so modular, reminds me of the s4. I wish more phone were like it!!
Lucas - 回复
Busted my screen running it up the side to pry it off. Next time I'd do the two bottom sides and lift up. The tapered edge on top seems to have been the problem for me.
Randy - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 9,709
