跳转到主内容
LG G5 Camera Sensor Replacement
你所需要的
  1. LG G5 Camera Sensor Replacement, Front Panel Assembly: 步骤 1 中的图像 1,2 LG G5 Camera Sensor Replacement, Front Panel Assembly: 步骤 1 中的图像 2,2
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Camera Sensor Replacement: 步骤 2 中的图像 1,3 LG G5 Camera Sensor Replacement: 步骤 2 中的图像 2,3 LG G5 Camera Sensor Replacement: 步骤 2 中的图像 3,3
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Camera Sensor Replacement: 步骤 3 中的图像 1,2 LG G5 Camera Sensor Replacement: 步骤 3 中的图像 2,2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Camera Sensor Replacement: 步骤 4 中的图像 1,1
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
  5. LG G5 Camera Sensor Replacement: 步骤 5 中的图像 1,2 LG G5 Camera Sensor Replacement: 步骤 5 中的图像 2,2
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
  6. LG G5 Camera Sensor Replacement: 步骤 6 中的图像 1,2 LG G5 Camera Sensor Replacement: 步骤 6 中的图像 2,2
    • Peel the screen away from the body. The two parts should be completely separated.
  7. LG G5 Camera Sensor Replacement, Screen: 步骤 7 中的图像 1,2 LG G5 Camera Sensor Replacement, Screen: 步骤 7 中的图像 2,2
    • Once the screen has been separated from the back of the phone, now you can remove the motherboard.
    • Using the #00 Philips head, remove the six 2.7mm Phillips screws.
  8. LG G5 Camera Sensor Replacement: 步骤 8 中的图像 1,2 LG G5 Camera Sensor Replacement: 步骤 8 中的图像 2,2
    • Insert the plastic opening tool between the screen-ribbon-connector and the motherboard, then pull up. It should pop out easily.
  9. LG G5 Camera Sensor Replacement: 步骤 9 中的图像 1,1
    • Separate the motherboard of the phone from the screen of the phone
  10. LG G5 Camera Sensor Replacement: 步骤 10 中的图像 1,2 LG G5 Camera Sensor Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • Make sure to transfer the earpiece from the old screen to the new screen or else you wouldn't be able to hear anyone when you make phone calls!
    • The component is fragile so don't try to force it to come out with a pair of tweezers. A pick should be able to wedge it out.
    • Be careful with the adhesive that's connected to it. It's easy to pull out.
  11. LG G5 Camera Sensor Replacement: 步骤 11 中的图像 1,1
    • Also remove the earpiece casing from the old screen by popping it out with a pair of tweezers.
    • On the new screen, place the casing down first and making sure that it's locked in place. Then place the earpiece on top of it. Gently push it down with your finger until it's secure.
  12. LG G5 Camera Sensor Replacement, Camera Sensor: 步骤 12 中的图像 1,3 LG G5 Camera Sensor Replacement, Camera Sensor: 步骤 12 中的图像 2,3 LG G5 Camera Sensor Replacement, Camera Sensor: 步骤 12 中的图像 3,3
    • Using the plastic opening tool, remove the ribbon attaching the sensor to the motherboard.
结论
6等其他人完成本指南。
Parker Reynolds
于10/03/16注册
936 声望
创作了2篇指南
团队
Cal Poly, Team 18-2, Forte Fall 2016 Cal Poly, Team 18-2, Forte Fall 2016 的会员
CPSU-FORTE-F16S18G2
4 名成员
创作了15篇指南
1指南评论
Is that the camera sensor that has been removed or the wide angle camera?
Thomas Charnley - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 59
总计 4,773
