跳转到主内容
LG G5 Battery Replacement
你所需要的
  1. LG G5 Battery Replacement, Battery: 步骤 1 中的图像 1,3 LG G5 Battery Replacement, Battery: 步骤 1 中的图像 2,3 LG G5 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Battery Replacement: 步骤 2 中的图像 1,2 LG G5 Battery Replacement: 步骤 2 中的图像 2,2
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
    You should be able to pull it out by pulling down and away at the same time.
    This video has a better explanation of how its done.
    Germanetti Rosas - 回复
    Para temover a bateria, é só puxar???
    eliezerhenriquesilva - 回复
结论
21等其他人完成本指南。
Sam Goldheart
于10/18/12注册
465,744 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,767篇指南
4条评论
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - 回复
Was machen wenn Akku Snap In ab ist?
Ra Ku - 回复
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Ra Ku - 回复
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 71
总计 15,545
