跳转到主内容
加入维修社区 - 创建账户
LG G5 Battery Replacement
你所需要的
  1. LG G5 Battery Replacement, Battery: 步骤 1 中的图像 1,3 LG G5 Battery Replacement, Battery: 步骤 1 中的图像 2,3 LG G5 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Battery Replacement: 步骤 2 中的图像 1,2 LG G5 Battery Replacement: 步骤 2 中的图像 2,2
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
结论
22等其他人完成本指南。
Sam Goldheart
于10/18/12注册
475,959 声望
创作了538篇指南
4指南评论
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - 回复 分享
Was machen wenn Akku Snap In ab ist?
Ra Ku - 回复 分享
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Ra Ku - 回复 分享
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 27
过去 30 天: 108
总计 17,093
