跳转到主内容
LG G4 Speaker Replacement
你所需要的
  1. LG G4 Speaker Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Speaker Replacement: 步骤 2 中的图像 1,2 LG G4 Speaker Replacement: 步骤 2 中的图像 2,2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Speaker Replacement: 步骤 3 中的图像 1,3 LG G4 Speaker Replacement: 步骤 3 中的图像 2,3 LG G4 Speaker Replacement: 步骤 3 中的图像 3,3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Speaker Replacement: 步骤 4 中的图像 1,3 LG G4 Speaker Replacement: 步骤 4 中的图像 2,3 LG G4 Speaker Replacement: 步骤 4 中的图像 3,3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 LG G4 Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Detach the bottom portion of the plastic panel you just removed by wedging the plastic opening tool under the top part of the clip, and sliding the bottom portion of the panel downward away from the top portion.
    • The bottom portion of the plastic panel contains the speaker to be replaced, all as one part.
结论
8等其他人完成本指南。
carolinavind
于08/30/15注册
2,699 声望
创作了3篇指南
团队
USF Tampa, Team 16-5, Wollert Fall 2015 USF Tampa, Team 16-5, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G5
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 17
总计 7,000
