简介
This guide will instruct you on how to replace a cracked or damaged LCD screen and digitizer assembly in your LG G4 smartphone.
It may be necessary to use a pre-cut LG G4 adhesive strip or Tesa 61395 tape to secure your new screen to your device.
Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
Front-facing camera connector.
Rear-facing camera connector.
Digitizer connector.
Use a heat gun or iOpener over the auxiliary port to soften the adhesive that secures it to the plastic housing.
Insert a nylon spudger into the auxiliary port and gently pry upward to free the port.
Use a spudger to carefully remove these components and then place them in the new display assembly..
Use a pair of tweezers to remove the adhesive strip that secures the digitizer ribbon cable.
Use a heavy duty suction cup and firmly pull the screen away from the frame to create a small gap.
Insert a plastic opening pick into the gap between the screen and the plastic housing.
Slide the plastic opening pick along the border of the screen to break any additional adhesive and free the screen assembly.
21等其他人完成本指南。
3条评论
Per the LG G4 Teardown guide, the glass, digitizer, and LCD are all fused together, so you have to replace the whole assembly
Lorsqu’on remplace l’ensemble écran + LCD achetés ensemble et que l’on transfère les pièces de l’ancien cadre (caméra, vibreur…), il ne faut pas oublier de transférer également 3 petits caoutchoucs carrés noir ou gris (2 en haut de chaque coté du haut parleur, et 1 en bas à gauche de la prise jack), sinon le détecteur de proximité ne marche pas et l’écran s’éteint et le reste lorsqu’on téléphone…
