跳转到主内容
LG G4 Headphone Port Replacement
你所需要的
  1. LG G4 Headphone Port Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Headphone Port Replacement: 步骤 2 中的图像 1,2 LG G4 Headphone Port Replacement: 步骤 2 中的图像 2,2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Headphone Port Replacement: 步骤 3 中的图像 1,3 LG G4 Headphone Port Replacement: 步骤 3 中的图像 2,3 LG G4 Headphone Port Replacement: 步骤 3 中的图像 3,3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Headphone Port Replacement: 步骤 4 中的图像 1,3 LG G4 Headphone Port Replacement: 步骤 4 中的图像 2,3 LG G4 Headphone Port Replacement: 步骤 4 中的图像 3,3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 Headphone Port Replacement, Headphone Port: 步骤 5 中的图像 1,2 LG G4 Headphone Port Replacement, Headphone Port: 步骤 5 中的图像 2,2
    • Gently wedge the plastic opening tool under the ribbons where each of the three cables are connected, and gently lift up to detach the cable.
    • This will allow you to remove the motherboard and give access the headphone port.
  6. LG G4 Headphone Port Replacement: 步骤 6 中的图像 1,2 LG G4 Headphone Port Replacement: 步骤 6 中的图像 2,2
    • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
  7. LG G4 Headphone Port Replacement: 步骤 7 中的图像 1,2 LG G4 Headphone Port Replacement: 步骤 7 中的图像 2,2
    • Place the plastic opening tool under the upper left corner of the headphone port, and lift up.
    • The headphone port is held in place with adhesive so it may take some time to pry it loose.
    • Remove the headphone port with your hands.
结论
7等其他人完成本指南。
Austin Stratton
于08/31/15注册
1,582 声望
创作了4篇指南
团队
USF Tampa, Team 16-5, Wollert Fall 2015 USF Tampa, Team 16-5, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G5
4 名成员
创作了20篇指南
8条评论
In step 5, there are actually three cables, not two.
krdkrdkrd - 回复
My g4's headphone could only produce sound on one side. So i bought a new headphone jack from ebay and replaced it. The problem still persists. Does this mean it could be a motherboard issue?
pholklorr - 回复
Or a headphone issue. You did try a different pair of headphones?
DarkAthena -
i did the same as pholklorr with my g4 but bought oem and still doesn't work you can only hear it from one side
titanzx2500 - 回复
Great! My headphone port couldn't hold my headphones anymore because of wear & tear (they kept falling out) but this guide and a 6 dollar ebay-item fixed it! Thanks a lot.
Moritz Bruder - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 23
总计 8,871
