跳转到主内容
LG G4 Front Camera Replacement
你所需要的
  1. LG G4 Front Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Front Camera Replacement: 步骤 2 中的图像 1,2 LG G4 Front Camera Replacement: 步骤 2 中的图像 2,2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Front Camera Replacement: 步骤 3 中的图像 1,3 LG G4 Front Camera Replacement: 步骤 3 中的图像 2,3 LG G4 Front Camera Replacement: 步骤 3 中的图像 3,3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Front Camera Replacement: 步骤 4 中的图像 1,3 LG G4 Front Camera Replacement: 步骤 4 中的图像 2,3 LG G4 Front Camera Replacement: 步骤 4 中的图像 3,3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 Front Camera Replacement, Front Camera: 步骤 5 中的图像 1,3 LG G4 Front Camera Replacement, Front Camera: 步骤 5 中的图像 2,3 LG G4 Front Camera Replacement, Front Camera: 步骤 5 中的图像 3,3
    • Detach the Front Camera ribbon cable located on the top right corner of the back of the phone by gently lifting it up with a plastic opening tool. Remove the front camera.
    • Be careful when removing the cables and pulling out the front camera to avoid tearing the attached cable.
结论
5等其他人完成本指南。
Austin Stratton
于08/31/15注册
1,576 声望
创作了4篇指南
团队
USF Tampa, Team 16-5, Wollert Fall 2015 USF Tampa, Team 16-5, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G5
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 4,114
