跳转到主内容
LG G3 Vigor Front Facing Camera Replacement
你所需要的
  1. LG G3 Vigor Front Facing Camera Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Front Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Front Facing Camera Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Front Facing Camera Replacement, Midframe: 步骤 4 中的图像 1,1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Front Facing Camera Replacement: 步骤 5 中的图像 1,3 LG G3 Vigor Front Facing Camera Replacement: 步骤 5 中的图像 2,3 LG G3 Vigor Front Facing Camera Replacement: 步骤 5 中的图像 3,3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Front Facing Camera Replacement, Front Facing Camera: 步骤 6 中的图像 1,2 LG G3 Vigor Front Facing Camera Replacement, Front Facing Camera: 步骤 6 中的图像 2,2
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard.
    • Remove the front camera.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 12-5, Eyestone Spring 2016 USF Tampa, Team 12-5, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S12G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 12
总计 276
