简介
1* Take the battery out.
2*Unscrew the whole back.
3*You will see a connector down at the charger port take them off and you can blow some air to take the dirt off.
4* Take some paper and fold it 4 to 6 times(small one)
5* After folding it make sure it is the size of the connector that is next to the Camera.
6*Place the folden paper on top of the connector.
7*Slowly get back all the plastic covers.
8*Screw in all the screws.
9*Place the battery, SD Card and the Sim back
10*Power on the Phone.
99.9% It will work.
UPDATE:
If you want to take it a step further,
get some thermal paste
and remove the whole circuit board and put some on the spot (as shown in the picture) do NOT put too much a dot will be enough...
after that, you can go ahead and place the circuit board back in place, then place the paper on the connector(follow the steps 6-10)
*Even thermal pad might do the job.
Thanks,
I hope this will fix the problem !
你所需要的
It is not to Hard to perform this Fix.
Just don't touch anything else and be careful while taking the plastic cover off....
Everything is going to be fine.
60等其他人完成本指南。
57条评论
Shume mire !! A ke Informacion si po ndrohet " Displayglass", jo krejt Display, po vetem ajo Pjesa e pare.
Tfala Bekim Jakupi
I am not sure who this is going to but I wanted to know about the repair of the flickering and fading screen of the LG G3. Is that procedure a long term fix and what causes the symptoms. Also is the little piece of paper any type of fire hazard. The repair worked and it blows my mind. Thank you so much. I brought my phone to a repair shop and they were unable to fix it, Thank you again. If you wish to respond to me. My name is rich and my E-MAIL address is raidernation61@sbcglobal.net.
do you have a gmail ? i want ask about this lg g3 problem . ty
wawan D -
Absolutely worked. Thanks for this. The flex cable just need to be push hard to the socket.
