跳转到主内容
LG G3 Screen Assembly Replacement
你所需要的
  1. LG G3 Screen Assembly Replacement, Back Cover: 步骤 1 中的图像 1,2 LG G3 Screen Assembly Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Screen Assembly Replacement: 步骤 2 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 2 中的图像 2,2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Screen Assembly Replacement, Battery: 步骤 3 中的图像 1,2 LG G3 Screen Assembly Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Screen Assembly Replacement: 步骤 4 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 4 中的图像 2,2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Screen Assembly Replacement, Loudspeaker: 步骤 5 中的图像 1,1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Screen Assembly Replacement: 步骤 6 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 6 中的图像 2,2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Screen Assembly Replacement: 步骤 7 中的图像 1,3 LG G3 Screen Assembly Replacement: 步骤 7 中的图像 2,3 LG G3 Screen Assembly Replacement: 步骤 7 中的图像 3,3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Screen Assembly Replacement, Motherboard Cover Assembly: 步骤 8 中的图像 1,1
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Screen Assembly Replacement: 步骤 9 中的图像 1,3 LG G3 Screen Assembly Replacement: 步骤 9 中的图像 2,3 LG G3 Screen Assembly Replacement: 步骤 9 中的图像 3,3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Screen Assembly Replacement: 步骤 10 中的图像 1,3 LG G3 Screen Assembly Replacement: 步骤 10 中的图像 2,3 LG G3 Screen Assembly Replacement: 步骤 10 中的图像 3,3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Screen Assembly Replacement, Motherboard: 步骤 11 中的图像 1,2 LG G3 Screen Assembly Replacement, Motherboard: 步骤 11 中的图像 2,2
    • Use a spudger to pry up and disconnect the display flex cable.
  12. LG G3 Screen Assembly Replacement: 步骤 12 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 12 中的图像 2,2
    • Use a spudger to pry up and disconnect the digitizer flex cable.
  13. LG G3 Screen Assembly Replacement: 步骤 13 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 13 中的图像 2,2
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  14. LG G3 Screen Assembly Replacement: 步骤 14 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 14 中的图像 2,2
    • Use a spudger to pry up and disconnect the front camera flex cable.
  15. LG G3 Screen Assembly Replacement: 步骤 15 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 15 中的图像 2,2
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
  16. LG G3 Screen Assembly Replacement: 步骤 16 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 16 中的图像 2,2
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
  17. LG G3 Screen Assembly Replacement: 步骤 17 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 17 中的图像 2,2
    • Grab the top section of the motherboard and carefully lift it out of the phone.
  18. LG G3 Screen Assembly Replacement, Screen Assembly: 步骤 18 中的图像 1,1
  19. LG G3 Screen Assembly Replacement: 步骤 19 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 19 中的图像 2,2
    • During the removal of the earpiece speaker, remove it together with the foam gasket underneath.
    • Use a pair of tweezers to remove the earpiece speaker.
  20. LG G3 Screen Assembly Replacement: 步骤 20 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 20 中的图像 2,2
    • Use a pair of tweezers to remove the front camera.
  21. LG G3 Screen Assembly Replacement: 步骤 21 中的图像 1,2 LG G3 Screen Assembly Replacement: 步骤 21 中的图像 2,2
    • If you're having trouble removing the rear camera or the vibration motor, reapply the heated iOpener to loosen the adhesive underneath.
    • Use a pair of tweezers to remove the rear camera.
  22. LG G3 Screen Assembly Replacement: 步骤 22 中的图像 1,3 LG G3 Screen Assembly Replacement: 步骤 22 中的图像 2,3 LG G3 Screen Assembly Replacement: 步骤 22 中的图像 3,3
    • Insert one of the tweezer arms under the vibration motor and pry it up.
    • Remove the vibration motor.
  23. LG G3 Screen Assembly Replacement: 步骤 23 中的图像 1,1
  24. LG G3 Screen Assembly Replacement: 步骤 24 中的图像 1,3 LG G3 Screen Assembly Replacement: 步骤 24 中的图像 2,3 LG G3 Screen Assembly Replacement: 步骤 24 中的图像 3,3
    • Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers.
  25. LG G3 Screen Assembly Replacement: 步骤 25 中的图像 1,3 LG G3 Screen Assembly Replacement: 步骤 25 中的图像 2,3 LG G3 Screen Assembly Replacement: 步骤 25 中的图像 3,3
    • Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly.
  26. LG G3 Screen Assembly Replacement: 步骤 26 中的图像 1,1
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing.
结论
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
If possible turn on your phone and test your replacement part before reassembling your phone.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
129等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
201,069 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了16,562篇指南
42条评论
Ok so after I did all this my screen is black and so I ordered a second screen and also nothing the phone works great and makes noises also touch responds but nothing on lcd just black can you help me with this also if I take battery out and plug up charger it shows a battery warning on lcd so clearly it works
cabinlife27030 - 回复
Has it sustained any water damage?
Josiah Leas -
Did you get it working i have the same issue? the picture displays with the original screen but not with the new one. i have tried 3 different screens and get the same on all of them. i even tried updating to the latest software but only get a black screen, no picture.
When i have had this on iphones i just so a reset by holding down the buttons and the screen starts to work.
Please someone help
Matt -
Same here! I also findout that lcd still works, if you get some flashlight on screen in a dark room, you will see that only backlight not working when battery plugged. I tried to baking it but it still didn't worked. It's obvious that backlight could properly operate as it works when you take off the battery. I'm looking for solutions, if I find any, will wrote it here.
tufekcisencer -
Did someone find a solution to this? I also replaced my screen and it keeps black solid when I turn it on, even with the touch working properly.
fsnaderfb -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 37
总计 248,604
