跳转到主内容
LG G3 Rear Facing Camera Lens Cover Replacement
你所需要的
视频概述
  1. LG G3 Rear Facing Camera Lens Cover Replacement, The damage: 步骤 1 中的图像 1,2 LG G3 Rear Facing Camera Lens Cover Replacement, The damage: 步骤 1 中的图像 2,2
    • A nice big rugged case is all good and well but it can't protect everything
  2. LG G3 Rear Facing Camera Lens Cover Replacement, Remove the battery cover: 步骤 2 中的图像 1,3 LG G3 Rear Facing Camera Lens Cover Replacement, Remove the battery cover: 步骤 2 中的图像 2,3 LG G3 Rear Facing Camera Lens Cover Replacement, Remove the battery cover: 步骤 2 中的图像 3,3
    • Locate the niche on the bottom right side of the phone.
    • You can use your finger nail or a pry tool to pop open the battery cover.
    • It is clipped on all around the phone. It shouldn't take too much force to open. It's quite easy to remove.
  3. LG G3 Rear Facing Camera Lens Cover Replacement, Remove camera lens cover: 步骤 3 中的图像 1,3 LG G3 Rear Facing Camera Lens Cover Replacement, Remove camera lens cover: 步骤 3 中的图像 2,3 LG G3 Rear Facing Camera Lens Cover Replacement, Remove camera lens cover: 步骤 3 中的图像 3,3
    • Remove the two screws holding the camera lens cover on. Keep in mind they are two different sizes. Short one up top, longer one on bottom. Use a small phillips head screwdriver. (sorry for removing them before taking the pic)
    • Remove the camera lens cover. I used my sharp pointed tweezers to pop the bottom of the cover up. It is also held in with small clips, much like the battery cover.
    • Save the volume/power button from the old cover and reuse it with the new camera lens cover.
  4. LG G3 Rear Facing Camera Lens Cover Replacement, Put new camera cover in: 步骤 4 中的图像 1,2 LG G3 Rear Facing Camera Lens Cover Replacement, Put new camera cover in: 步骤 4 中的图像 2,2
    • Clean the camera lens and the new camera lens cover. Put the new cover in. I put the left side in at an angle first and then popped the right side in to the clips. Don't use too much force or it could possibly break the plastic
    • Put the battery cover back on and slap your phone back in it's case if you have one. Done!
结论
20等其他人完成本指南。
Bohemian
于12/14/14注册
601 声望
撰写一个指南
9条评论
This guide gave me the push to fix my lens cap issue myself. Ordered replacement parts off ebay from china for real cheap and it took me all of five minutes to replace the lens cap. now my pictures turn out great and I know how to fix this minor issue. Thanks!
Billy - 回复
That's great to hear Billy. This phone is quite easy to fix. I might post another guide on it soon
Bohemian - 回复
Where I can by it
Naim Sadiku - 回复
I purchased mine from amazon
Bohemian - 回复
Excellent step by step. It is so simple yet without the confidence to even attempt to take the phone apart I would have not known. Thank you sir!
jasonstovall - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 28,910
