跳转到主内容
LG G3 Power & Volume Button Cable Replacement
你所需要的
  1. LG G3 Power & Volume Button Cable Replacement, Back Cover: 步骤 1 中的图像 1,2 LG G3 Power & Volume Button Cable Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Power & Volume Button Cable Replacement: 步骤 2 中的图像 1,2 LG G3 Power & Volume Button Cable Replacement: 步骤 2 中的图像 2,2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Power & Volume Button Cable Replacement, Battery: 步骤 3 中的图像 1,2 LG G3 Power & Volume Button Cable Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Power & Volume Button Cable Replacement: 步骤 4 中的图像 1,2 LG G3 Power & Volume Button Cable Replacement: 步骤 4 中的图像 2,2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Power & Volume Button Cable Replacement, Loudspeaker: 步骤 5 中的图像 1,1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Power & Volume Button Cable Replacement: 步骤 6 中的图像 1,2 LG G3 Power & Volume Button Cable Replacement: 步骤 6 中的图像 2,2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Power & Volume Button Cable Replacement: 步骤 7 中的图像 1,3 LG G3 Power & Volume Button Cable Replacement: 步骤 7 中的图像 2,3 LG G3 Power & Volume Button Cable Replacement: 步骤 7 中的图像 3,3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Power & Volume Button Cable Replacement, Motherboard Cover Assembly: 步骤 8 中的图像 1,1
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Power & Volume Button Cable Replacement: 步骤 9 中的图像 1,3 LG G3 Power & Volume Button Cable Replacement: 步骤 9 中的图像 2,3 LG G3 Power & Volume Button Cable Replacement: 步骤 9 中的图像 3,3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Power & Volume Button Cable Replacement: 步骤 10 中的图像 1,3 LG G3 Power & Volume Button Cable Replacement: 步骤 10 中的图像 2,3 LG G3 Power & Volume Button Cable Replacement: 步骤 10 中的图像 3,3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: 步骤 11 中的图像 1,2 LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: 步骤 11 中的图像 2,2
    • Remove the last screw attaching the rear camera lens to the frame.
    • Now use a plastic spudger to carefully remove the camera lens.
  12. LG G3 Power & Volume Button Cable Replacement: 步骤 12 中的图像 1,3 LG G3 Power & Volume Button Cable Replacement: 步骤 12 中的图像 2,3 LG G3 Power & Volume Button Cable Replacement: 步骤 12 中的图像 3,3
    • Using the spudger, release power & volume button flex from adhesive carefully.
  13. LG G3 Power & Volume Button Cable Replacement: 步骤 13 中的图像 1,1
    • Finally, remove the flex.
结论
9等其他人完成本指南。
Sophia
于03/25/14注册
43,810 声望
创作了62篇指南
一条评论
I bought a more powerful battery. 6800 mah .instead of the 3000mah OEM . Ia there any problem using it?
mitoll - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 21,997
