跳转到主内容
LG G3 Motherboard Replacement
你所需要的
  1. LG G3 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 LG G3 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Motherboard Replacement: 步骤 2 中的图像 1,2 LG G3 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Motherboard Replacement, Battery: 步骤 3 中的图像 1,2 LG G3 Motherboard Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Motherboard Replacement: 步骤 4 中的图像 1,2 LG G3 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Motherboard Replacement, Loudspeaker: 步骤 5 中的图像 1,1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Motherboard Replacement: 步骤 6 中的图像 1,2 LG G3 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Motherboard Replacement: 步骤 7 中的图像 1,3 LG G3 Motherboard Replacement: 步骤 7 中的图像 2,3 LG G3 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Motherboard Replacement, Motherboard Cover Assembly: 步骤 8 中的图像 1,1
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Motherboard Replacement: 步骤 9 中的图像 1,3 LG G3 Motherboard Replacement: 步骤 9 中的图像 2,3 LG G3 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Motherboard Replacement: 步骤 10 中的图像 1,3 LG G3 Motherboard Replacement: 步骤 10 中的图像 2,3 LG G3 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,2 LG G3 Motherboard Replacement, Motherboard: 步骤 11 中的图像 2,2
    • Use a spudger to pry up and disconnect the display flex cable.
  12. LG G3 Motherboard Replacement: 步骤 12 中的图像 1,2 LG G3 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Use a spudger to pry up and disconnect the digitizer flex cable.
  13. LG G3 Motherboard Replacement: 步骤 13 中的图像 1,2 LG G3 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  14. LG G3 Motherboard Replacement: 步骤 14 中的图像 1,2 LG G3 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Use a spudger to pry up and disconnect the front camera flex cable.
  15. LG G3 Motherboard Replacement: 步骤 15 中的图像 1,2 LG G3 Motherboard Replacement: 步骤 15 中的图像 2,2
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
  16. LG G3 Motherboard Replacement: 步骤 16 中的图像 1,2 LG G3 Motherboard Replacement: 步骤 16 中的图像 2,2
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
  17. LG G3 Motherboard Replacement: 步骤 17 中的图像 1,2 LG G3 Motherboard Replacement: 步骤 17 中的图像 2,2
    • Grab the top section of the motherboard and carefully lift it out of the phone.
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
4等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
165,878 声望
创作了661篇指南
团队
iFixit iFixit 的会员
Community
137 名成员
创作了17,055篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 31
总计 2,818
