跳转到主内容
LG G2 mini LTE Rear Facing Camera Replacement
你所需要的
  1. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Battery Cover: 步骤 1 中的图像 1,1
    • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
    • Pry upward and the cover should pop off easily.
  2. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Battery: 步骤 2 中的图像 1,1
    • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
  3. LG G2 mini LTE Rear Facing Camera Replacement, Unscrew the Motherboard Cover: 步骤 3 中的图像 1,2 LG G2 mini LTE Rear Facing Camera Replacement, Unscrew the Motherboard Cover: 步骤 3 中的图像 2,2
    • Locate 10 screws and remove each one using a screw driver.
  4. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Motherboard Cover: 步骤 4 中的图像 1,1
    • Use a plastic spudger tool to pry away the cover by placing it between the cover and the screen bezel.
    • Pry all the way around the phone about every centimeter until the cover is completely separated from the phone.
  5. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: 步骤 5 中的图像 1,3 LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: 步骤 5 中的图像 2,3 LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: 步骤 5 中的图像 3,3
    • Locate the rear facing camera.
    • Pry the ribbon cable off of it's connector using the plastic spudger tool.
    • Use your finger to remove the camera.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team 1-9, Shastany Fall 2014 UMass Dartmouth, Team 1-9, Shastany Fall 2014 的会员
UMASSD-SHASTANY-F14S1G9
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 1,658
