简介
Having trouble charging your phone? Here is a guide to replace a faulty charger port. Make sure to keep track of the parts you remove. The phone has many small screws, antennae, and ribbons that need to be worked with.
你所需要的
Use a plastic opening tool to pry open your phone case. Flip the phone over and start by sliding your tool between the two sides of your phone case. Work the tool towards the bottom of the phone case, gently prying the case open. There is a clip that will pop open after applying gentle but consistent pressure.
Make sure to release the clip on the top left corner of the phone case carefully. This is usually the most difficult clip to release.
另外一个人完成了本指南。
