跳转到主内容
LG G Watch R Motherboard Replacement
你所需要的
  1. LG G Watch R Motherboard Replacement, Back Case: 步骤 1 中的图像 1,2 LG G Watch R Motherboard Replacement, Back Case: 步骤 1 中的图像 2,2
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the back case.
  4. LG G Watch R Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 LG G Watch R Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Motherboard Replacement: 步骤 5 中的图像 1,2 LG G Watch R Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Motherboard Replacement: 步骤 6 中的图像 1,1
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
结论
3等其他人完成本指南。
Westley Courchene
于01/13/15注册
3,362 声望
创作了14篇指南
团队
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 的会员
USFT-REMMELL-F15S1G1
5 名成员
创作了14篇指南
3条评论
Thanks for this! None of the other fixes worked, so I tried this as a last resort with a motherboard borrowed from another G Watch, and it did the trick. So now I know the motherboard was the problem.
H Arumph - 回复
Where do I buy a replacement motherboard from??
Brandon Reznik - 回复
Did you ever find anywhere to order a replacement motherboard?
Robert Dye -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 3,176
