跳转到主内容
LG G Watch Gasket Replacement
你所需要的
  1. LG G Watch Gasket Replacement, Wristband: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Gasket Replacement: 步骤 2 中的图像 1,2 LG G Watch Gasket Replacement: 步骤 2 中的图像 2,2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Gasket Replacement, Rear Case: 步骤 3 中的图像 1,1
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Gasket Replacement: 步骤 4 中的图像 1,2 LG G Watch Gasket Replacement: 步骤 4 中的图像 2,2
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Gasket Replacement, Gasket: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
结论
另外一个人完成了本指南。
Deja Miller
于10/14/14注册
462 声望
创作了3篇指南
团队
USF Tampa, Team 2-5, Blackwell Fall 2014 USF Tampa, Team 2-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S2G5
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 685
