跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband. Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  5. Slide the opening pick between the rear case and the rest of the device to separate the two halves. Gently pull the two halves apart.
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  6. Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
  7. Use the spudger to gently lift up and disconnect the display connector. Now use the spudger to disconnect the digitizer connector.
    • Use the spudger to gently lift up and disconnect the display connector.
    • Now use the spudger to disconnect the digitizer connector.
  8. Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws. Use the spudger to gently remove the motherboard.
    • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
    • Use the spudger to gently remove the motherboard.
  9. Apply a small amount of pressure to the back of the LCD to create a gap for the opening pick.
    • Apply a small amount of pressure to the back of the LCD to create a gap for the opening pick.
    • Gently work the pick around the perimeter of the device to loosen up the adhesive.
    • An iOpener may be necessary to help loosen up the adhesive. Refer to our iOpener guide for info on how to use it.
  10. After using the pick to loosen the adhesive, simply pull the display assembly up from the metal bezel. After using the pick to loosen the adhesive, simply pull the display assembly up from the metal bezel.
    • After using the pick to loosen the adhesive, simply pull the display assembly up from the metal bezel.
结论
3等其他人完成本指南。
Mandy McGarry
于2014年09月23日注册
165 信誉积分
撰写一个指南
团队
USF Tampa, Team 2-5, Blackwell Fall 2014 USF Tampa, Team 2-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S2G5
5 名成员
创作了5篇指南
Where can you purchase replacement parts?
Brian Winebarger - 回复
Someone knows where to find a screen replacement?, i found at alibaba but i have to buy 1k ... :(
George Momo Seyssel - 回复
I found a 00 screwdriver was better than 000 for removing the motherboard.
Peter Jeremy - 回复
添加评论
浏览统计数据:
过去的24小时: 6
过去的7天: 6
过去的30天: 20
总计 3,957
