跳转到主内容
LG G Vista Motherboard Replacement
你所需要的
  1. LG G Vista Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the device is powered off.
  2. LG G Vista Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Motherboard Replacement: 步骤 3 中的图像 1,1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Remove the eight 3.0 mm screws using the Phillips #000 screwdriver.
  5. LG G Vista Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the hard shell covering the motherboard.
  6. LG G Vista Motherboard Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to lift up the white antenna wire. On the other side of the logic board, do the same for the black antenna wire.
  7. LG G Vista Motherboard Replacement: 步骤 7 中的图像 1,2 LG G Vista Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use the tweezers to remove the four connectors as well as the back camera.
    • Be careful not to directly touch the camera lenses.
  8. LG G Vista Motherboard Replacement: 步骤 8 中的图像 1,1
    • Lift up and remove the motherboard from the device.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 482
