跳转到主内容
LG G Vista Charging Dock Replacement
你所需要的
  1. LG G Vista Charging Dock Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the device is powered off.
  2. LG G Vista Charging Dock Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Charging Dock Replacement: 步骤 3 中的图像 1,1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Charging Dock Replacement, Charging Dock: 步骤 4 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the eleven 3.0 mm screws around the perimeter of the phone.
  5. LG G Vista Charging Dock Replacement: 步骤 5 中的图像 1,1
    • Use a plastic spudger, or finger nail, to lift up the hard shell on the top of the phone.
  6. LG G Vista Charging Dock Replacement: 步骤 6 中的图像 1,2 LG G Vista Charging Dock Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the five 3.0 mm screws.
    • Remove the bottom hard shell from the device.
  7. LG G Vista Charging Dock Replacement: 步骤 7 中的图像 1,2 LG G Vista Charging Dock Replacement: 步骤 7 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the two screws from the device.
  8. LG G Vista Charging Dock Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using a pair of tweezers, lift up the two antennas surrounding the battery.
  9. LG G Vista Charging Dock Replacement: 步骤 9 中的图像 1,1
    • Disconnect the two connectors on the right side of the charging port.
  10. LG G Vista Charging Dock Replacement: 步骤 10 中的图像 1,1
    • Lift up the charging port with the plastic opening tool.
    • Remove the charging port from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 657
