跳转到主内容
LG G Stylo Motherboard Replacement
你所需要的
  1. LG G Stylo Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LG G Stylo Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. LG G Stylo Motherboard Replacement: 步骤 2 中的图像 1,2 LG G Stylo Motherboard Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
    My phone is showing USB when charging instead of AC and when removing the charger it's show discharging instead of Not charging.... Don't know why it is not working properly....
    George japhet - 回复
    I need help urgently please
    George japhet - 回复
  3. LG G Stylo Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 LG G Stylo Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Carefully use the Phillips #00 screwdriver to remove the eleven 3.9mm visible screws found on the back. The screws to be removed are marked with the given indicators.
  4. LG G Stylo Motherboard Replacement: 步骤 4 中的图像 1,3 LG G Stylo Motherboard Replacement: 步骤 4 中的图像 2,3 LG G Stylo Motherboard Replacement: 步骤 4 中的图像 3,3
    • When you have finished removing all of the screws, place the plastic opening tool in the groove at the bottom left corner of the motherboard cover and lift up.
    • Make sure to remove the SIM card before you remove the motherboard cover. You can get the cover off without doing this, but the SIM card will be stuck underneath the cover once you put it back together.
    • This part could be more difficult if you have never removed the motherboard cover. If difficulty arises, pry the plastic opening tool into each groove along the edge of the motherboard cover until it releases.
    • Once a clip is released, you can detach the motherboard cover with your fingers and set aside.
  5. LG G Stylo Motherboard Replacement: 步骤 5 中的图像 1,3 LG G Stylo Motherboard Replacement: 步骤 5 中的图像 2,3 LG G Stylo Motherboard Replacement: 步骤 5 中的图像 3,3
    • Carefully place the plastic opening tool under the ribbons where the cables are connecting and lift up to detach the cables.
    • Keep in mind to be careful with the ribbons, because they are small components and important for the device's functionality.
    • The third photo attached depicts what the ribbons look like when they are successfully detached.
  6. LG G Stylo Motherboard Replacement: 步骤 6 中的图像 1,2 LG G Stylo Motherboard Replacement: 步骤 6 中的图像 2,2
    • Fully remove the motherboard by prying upward with the plastic opening tool.
    • This step will be quite simple if all the ribbons have been detached correctly.
    These pictures sb. numbered
    superbike-shaun - 回复
    The pictures shown need to be#”d and also what part # do we order???
结论
6等其他人完成本指南。
团队
USF Tampa, Team 11-7, Cheng Spring 2016 USF Tampa, Team 11-7, Cheng Spring 2016 的会员
USFT-CHENG-S16S11G7
4 名成员
创作了14篇指南
6条评论
Do you know where the wifi chip is?
Jeremy Vega - 回复
Do you guys know where i can get a new motherboard for an lg stylo?
Alessandro Enceladus - 回复
A family member of mine snapped my phone in half with my baby's pictures on it.
I asked my boyfriend to back up the pictures… well, he figured after thanksgiving when I will have more happy photos…
So, any hope of getting them?
The motherboard is partly missing.
The SD card was full so most were on the phone.
Lost Cause - 回复
My LG stylus 2 power ic is damaged can you repair it please
Tusha - 回复
I would like to know if I can change the micro USB charging port to the'C’ type on a k20
Ron Hardy - 回复
Achte carte mere LG stylus2 vs 2016
Bahaa Eddinne - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 19
总计 7,097
