跳转到主内容
简介
If your phone dies quickly even when it was full charged or doesn't even charge at all, this guide will walk you through how to replace the battery of your phone. Only tool you need for this guide is plastic opening tool.
  1. Make sure that you power off the phone before beginning. Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers. Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
    My phone is showing USB when charging instead of AC and when removing the charger it's show discharging instead of Not charging.... Don't know why it is not working properly....
    George japhet - 回复
    I need help urgently please
    George japhet - 回复
结论
6等其他人完成本指南。
Douglas Schmidt
于2016年02月09日注册
392 信誉积分
创作了2篇指南
团队
USF Tampa, Team 11-7, Cheng Spring 2016 USF Tampa, Team 11-7, Cheng Spring 2016 的会员
USFT-CHENG-S16S11G7
4 名成员
创作了14篇指南
一条评论
Thank you for your help. This has been making us crazy, your time is much appreciated.
Desi Young - 回复
添加评论
浏览统计数据:
过去的24小时: 8
过去的7天: 24
过去的30天: 119
总计 9,999
