简介
If your phone dies quickly even when it was full charged or doesn't even charge at all, this guide will walk you through how to replace the battery of your phone. Only tool you need for this guide is plastic opening tool.
你所需要的
Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
My phone is showing USB when charging instead of AC and when removing the charger it's show discharging instead of Not charging.... Don't know why it is not working properly....
I need help urgently please
6等其他人完成本指南。
一条评论
Thank you for your help. This has been making us crazy, your time is much appreciated.
Desi Young - 回复
