简介
If there is no sound or if the quality of the speaker has diminished significantly, it may be time for a replacement. This guide will walk you through the process of replacing the speaker in your LG G Pad X 8.3.
你所需要的
Remove the cover of the SD card. Find it on the right side of the back of the tablet.
Press the SD card in to make it pop out.
With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
Use the magnetic mat to keep track of the tiny screw(s).
即将完成!
结论
