跳转到主内容
LG G Pad X 8.0 Motherboard Replacement
你所需要的
  1. LG G Pad X 8.0 Motherboard Replacement, Removing Backplate: 步骤 1 中的图像 1,1
    • Power off the device before starting battery replacement.
    • Remove SD card and SIM Card.
    • With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
  2. LG G Pad X 8.0 Motherboard Replacement, Peeling Back Cover Off: 步骤 2 中的图像 1,2 LG G Pad X 8.0 Motherboard Replacement, Peeling Back Cover Off: 步骤 2 中的图像 2,2
    • Gently pull the back cover away from the adhesive on the battery.
    • It may be possible to use a blow dryer on low heat but I'd advise against it unless absolutely necessary.
  3. LG G Pad X 8.0 Motherboard Replacement, Detaching Old Battery: 步骤 3 中的图像 1,3 LG G Pad X 8.0 Motherboard Replacement, Detaching Old Battery: 步骤 3 中的图像 2,3 LG G Pad X 8.0 Motherboard Replacement, Detaching Old Battery: 步骤 3 中的图像 3,3
    • Slowly and gently lift the power cable upwards.
    • Unscrew the 4 screws keeping the battery in place, set aside.
  4. LG G Pad X 8.0 Motherboard Replacement, Removing the Battery: 步骤 4 中的图像 1,1
    • Remove the battery by pulling up gently.
  5. LG G Pad X 8.0 Motherboard Replacement, Disconnect Cables: 步骤 5 中的图像 1,3 LG G Pad X 8.0 Motherboard Replacement, Disconnect Cables: 步骤 5 中的图像 2,3 LG G Pad X 8.0 Motherboard Replacement, Disconnect Cables: 步骤 5 中的图像 3,3
    • Pry the connector for the camera up.
    • Pry the connector for the USB module up.
    • Pry the cable connecting the metal circle.
  6. LG G Pad X 8.0 Motherboard Replacement, Remove screws: 步骤 6 中的图像 1,3 LG G Pad X 8.0 Motherboard Replacement, Remove screws: 步骤 6 中的图像 2,3 LG G Pad X 8.0 Motherboard Replacement, Remove screws: 步骤 6 中的图像 3,3
    • Unscrew the 3 screws holding the USB module down.
    • Unscrew the 2 screws keeping the motherboard in place.
    • Finally, the two screws for the micro USB port.
  7. LG G Pad X 8.0 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently lift up the display connector.
    • Be careful, too much pressure can cause the digitizer/screen to crack as it is right below the metal.
  8. LG G Pad X 8.0 Motherboard Replacement, Removing the Motherboard: 步骤 8 中的图像 1,1
    • Remove the motherboard by pulling it straight up and away from the tablet body.
结论
4等其他人完成本指南。
[deleted]
于05/18/17注册
1,146 声望
创作了3篇指南
2条评论
Would my motherboard to my pad be no good due to water damage it’s been 3 months still won’t turn on. The little sticker is pink still but my battery smells burnt. Could I take out the mother and use some air dust ?
Joe - 回复
You may need to replace the battery as it sounds like it shorted out. A burnt smell more than likely means the battery is damaged.
Have you tried replacing the battery yet?
[deleted] -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,828
