跳转到主内容
LG G Pad X 8.0 Battery Replacement
你所需要的
  1. LG G Pad X 8.0 Battery Replacement, Removing Backplate: 步骤 1 中的图像 1,1
    • Power off the device before starting battery replacement.
    • Remove SD card and SIM Card.
    • With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
  2. LG G Pad X 8.0 Battery Replacement, Peeling Back Cover Off: 步骤 2 中的图像 1,2 LG G Pad X 8.0 Battery Replacement, Peeling Back Cover Off: 步骤 2 中的图像 2,2
    • Gently pull the back cover away from the adhesive on the battery.
    • It may be possible to use a blow dryer on low heat but I'd advise against it unless absolutely necessary.
  3. LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: 步骤 3 中的图像 1,3 LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: 步骤 3 中的图像 2,3 LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: 步骤 3 中的图像 3,3
    • Slowly and gently lift the power cable upwards.
    • Unscrew the 4 screws keeping the battery in place, set aside.
  4. LG G Pad X 8.0 Battery Replacement, Removing the Battery: 步骤 4 中的图像 1,1
    • Remove the battery by pulling up gently.
结论
17等其他人完成本指南。
[deleted]
于05/18/17注册
1,146 声望
创作了3篇指南
10条评论
I was going to do this to fix my son's tablet and then I looked up the cost of a replacement battery on eBay. Almost $100! Do you have a good source for a new battery?
poeticpyr07 - 回复
Unfortunately, no, there does not seem to be a good part supplier for the G Pad X 8.0. As you mention, the best I see is eBay at $82.
[deleted] -
2 years on they're $14
Carlos Mendonca -
I have researched this battery, the LG BL T-20. I found one that is 4800 MaH. The LG Gpad X8.0 has the same battery that is 4650 MaH. If I order the 4800 MaH, will it work?
luvgod10 - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 21
过去 30 天: 46
总计 14,963
