跳转到主内容
LG G Pad F 8.0 Motherboard Replacement
你所需要的
  1. LG G Pad F 8.0 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 LG G Pad F 8.0 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Place the tablet with the screen facing down.
    • Open the SIM port on the top right corner of the tablet.
    • Press the SIM card to pop it out.
    • Remove the SIM card from the tablet.
  2. LG G Pad F 8.0 Motherboard Replacement: 步骤 2 中的图像 1,2 LG G Pad F 8.0 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use the iFixit opening tool to pry the back cover off of the tablet.
    • Work your way all the way around the edge of the screen, and remove the back cover when it is loose.
  3. LG G Pad F 8.0 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Disconnect the large, yellow ribbon using the iFixit opening tool.
  4. LG G Pad F 8.0 Motherboard Replacement: 步骤 4 中的图像 1,3 LG G Pad F 8.0 Motherboard Replacement: 步骤 4 中的图像 2,3 LG G Pad F 8.0 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use the iFixit opening tool to disconnect the multicolor wire cables from the motherboard.
    • Disconnect the top of the orange ribbon cable from the motherboard.
    • Detach the front facing camera ribbon cable from the motherboard.
  5. LG G Pad F 8.0 Motherboard Replacement: 步骤 5 中的图像 1,3 LG G Pad F 8.0 Motherboard Replacement: 步骤 5 中的图像 2,3 LG G Pad F 8.0 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Remove the seven 2 mm screws using a Phillips #0 screwdriver.
    • Use the iFixit opening tool and pry up on the motherboard to remove it.
结论
Angel Padilla
于02/09/23注册
97 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 131
