跳转到主内容
LG G Pad F 7.0 Speaker Replacement
你所需要的
  1. LG G Pad F 7.0 Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 LG G Pad F 7.0 Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Speaker Replacement: 步骤 2 中的图像 1,2 LG G Pad F 7.0 Speaker Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Speaker Replacement: 步骤 3 中的图像 1,3 LG G Pad F 7.0 Speaker Replacement: 步骤 3 中的图像 2,3 LG G Pad F 7.0 Speaker Replacement: 步骤 3 中的图像 3,3
    • Locate the LG G Pad F 7.0 speaker
    • Insert the plastic opening tool on an edge of the speaker and lift so that it comes off easily
    • Remove old speaker and replace with a new one
结论
2等其他人完成本指南。
Jose Hurtado
于01/25/17注册
329 声望
创作了2篇指南
团队
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 181
