跳转到主内容
LG G Pad F 7.0 Charging Port Replacement
你所需要的
  1. LG G Pad F 7.0 Charging Port  Replacement, Charging Port: 步骤 1 中的图像 1,2 LG G Pad F 7.0 Charging Port  Replacement, Charging Port: 步骤 1 中的图像 2,2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Charging Port  Replacement: 步骤 2 中的图像 1,2 LG G Pad F 7.0 Charging Port  Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Charging Port  Replacement: 步骤 3 中的图像 1,1
    • Locate the top of the large orange ribbon cable.
    • Pry it off with the plastic opening tool as shown in the image.
  4. LG G Pad F 7.0 Charging Port  Replacement: 步骤 4 中的图像 1,2 LG G Pad F 7.0 Charging Port  Replacement: 步骤 4 中的图像 2,2
    • Remove the gyroscope (the blue rectangular cube) located near the bottom of the device with the plastic opening tool as shown in the image.
    • Remove the speaker located in the bottom right corner of the device with the plastic opening tool as shown in the image.
  5. LG G Pad F 7.0 Charging Port  Replacement: 步骤 5 中的图像 1,2 LG G Pad F 7.0 Charging Port  Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the two screws located on the charging port as seen in the image using the Phillips screwdriver.
    • Using the tweezers, remove the orange ribbon cable along with the charging port.
结论
7等其他人完成本指南。
Erik
于01/25/17注册
293 声望
撰写一个指南
团队
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G5
3 名成员
创作了10篇指南
4条评论
Good work, Pictures are clear and easy to follow
Jonah Basl - 回复
Just a minor item. On step 4 it tells you to remove the gyroscope, then remove the speaker. On on the unit I worked in you had to remove the speaker so you could get remove the gyroscope. I was working on the 8.0 instead of the 7.0 model, so perhaps that accounted for the difference.
Alan Siebens - 回复
Where do you buy the new charging port you need to put in? It's like gold lined teeth top and bottom.
Stands For Jesus - 回复
Also on his LG can we turn it into a prepaid monthly service if we get a at&t sim card kit or something similar?
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 14
总计 4,066
