跳转到主内容
LG G Pad F 7.0 Battery Replacement
你所需要的
  1. LG G Pad F 7.0 Battery Replacement, Battery: 步骤 1 中的图像 1,2 LG G Pad F 7.0 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Battery Replacement: 步骤 2 中的图像 1,2 LG G Pad F 7.0 Battery Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Battery Replacement: 步骤 3 中的图像 1,1
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  4. LG G Pad F 7.0 Battery Replacement: 步骤 4 中的图像 1,2 LG G Pad F 7.0 Battery Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
结论
Matt Kloos
于01/25/17注册
249 声望
创作了2篇指南
团队
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S8G5
3 名成员
创作了10篇指南
一条评论
Pictures are all in focus and easy to follow
Jonah Basl - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 12
总计 688
