跳转到主内容
LG G Pad 8.3 4G Vibrator Replacement
你所需要的
  1. LG G Pad 8.3 4G Vibrator Replacement, Back Panel: 步骤 1 中的图像 1,1
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Vibrator Replacement: 步骤 2 中的图像 1,3 LG G Pad 8.3 4G Vibrator Replacement: 步骤 2 中的图像 2,3 LG G Pad 8.3 4G Vibrator Replacement: 步骤 2 中的图像 3,3
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
  3. LG G Pad 8.3 4G Vibrator Replacement, Vibrator: 步骤 3 中的图像 1,2 LG G Pad 8.3 4G Vibrator Replacement, Vibrator: 步骤 3 中的图像 2,2
    • Remove the two screws on the white panel on the bottom right side.
  4. LG G Pad 8.3 4G Vibrator Replacement: 步骤 4 中的图像 1,2 LG G Pad 8.3 4G Vibrator Replacement: 步骤 4 中的图像 2,2
    • Remove the white panel.
  5. LG G Pad 8.3 4G Vibrator Replacement: 步骤 5 中的图像 1,1
    • Remove the vibrator from the underside of the white panel.
结论
Justice Hindenburg
于09/18/18注册
97 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 145
