跳转到主内容
LG G Pad 8.3 4G Speakers Replacement
你所需要的
  1. LG G Pad 8.3 4G Speakers Replacement, Back Panel: 步骤 1 中的图像 1,1
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Speakers Replacement: 步骤 2 中的图像 1,3 LG G Pad 8.3 4G Speakers Replacement: 步骤 2 中的图像 2,3 LG G Pad 8.3 4G Speakers Replacement: 步骤 2 中的图像 3,3
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
  3. LG G Pad 8.3 4G Speakers Replacement, Speakers: 步骤 3 中的图像 1,2 LG G Pad 8.3 4G Speakers Replacement, Speakers: 步骤 3 中的图像 2,2
    • Remove the 4 1.5 mm screws holding the speakers in place.
  4. LG G Pad 8.3 4G Speakers Replacement: 步骤 4 中的图像 1,3 LG G Pad 8.3 4G Speakers Replacement: 步骤 4 中的图像 2,3 LG G Pad 8.3 4G Speakers Replacement: 步骤 4 中的图像 3,3
    • Put the spudger underneath the gold cap of the cable and lift to disconnect from device.
    • This cable can be damaged easily.
  5. LG G Pad 8.3 4G Speakers Replacement: 步骤 5 中的图像 1,1
    • Pull the cable back and out of the way of the speaker.
  6. LG G Pad 8.3 4G Speakers Replacement: 步骤 6 中的图像 1,2 LG G Pad 8.3 4G Speakers Replacement: 步骤 6 中的图像 2,2
    • Place the spudger in between the speaker and the device to pop the speaker out of place.
    • Pull the speaker out of the device.
结论
Deja Morrow
于09/18/18注册
109 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 125
