跳转到主内容
LG G Pad 8.3 4G Back Panel Replacement
你所需要的
  1. LG G Pad 8.3 4G Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Back Panel Replacement: 步骤 2 中的图像 1,3 LG G Pad 8.3 4G Back Panel Replacement: 步骤 2 中的图像 2,3 LG G Pad 8.3 4G Back Panel Replacement: 步骤 2 中的图像 3,3
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 379
