工具
配件
没有特定配件。
这个步骤还没有翻译 帮忙翻译一下
The screen assembly is secured to the plastic backing with clips. Insert the plastic opening tool between the screen and plastic.
Work your way around the device, freeing it from the connecting clips.
Lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
这个步骤还没有翻译 帮忙翻译一下
Remove the red marked connectors by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
You will have to remove the metallic tape near the bottom of the tablet to disconnect the display cable.
Remove the three connectors marked in orange by gently prying them upwards. The cables are very fragile so be careful not to rip them.
3等其他人完成本指南。
