跳转到主内容
LG G Pad 7.0 LTE Front Screen Replacement
你所需要的
  1. LG G Pad 7.0 LTE Front Screen Replacement, Open up the tablet: 步骤 1 中的图像 1,3 LG G Pad 7.0 LTE Front Screen Replacement, Open up the tablet: 步骤 1 中的图像 2,3 LG G Pad 7.0 LTE Front Screen Replacement, Open up the tablet: 步骤 1 中的图像 3,3
    • Remove the MicroSD Memory card, Sim Card, and the metal Sim Card Holder.
    • Put them off to the side for reassembly.
    • Now you can slowly use a plastic opening tool to go around the edge of the tablet to slowly pry upward.
  2. LG G Pad 7.0 LTE Front Screen Replacement, Remove the orange port strip: 步骤 2 中的图像 1,3 LG G Pad 7.0 LTE Front Screen Replacement, Remove the orange port strip: 步骤 2 中的图像 2,3 LG G Pad 7.0 LTE Front Screen Replacement, Remove the orange port strip: 步骤 2 中的图像 3,3
    • Now that we have the back cover and can remove the orange port strip.
    • Use the spudger to gently remove the strip by pushing upward slowly.
  3. LG G Pad 7.0 LTE Front Screen Replacement, Disconnect the battery: 步骤 3 中的图像 1,2 LG G Pad 7.0 LTE Front Screen Replacement, Disconnect the battery: 步骤 3 中的图像 2,2
    • To disconnect the battery you are going to unplug the cables.
    • Use the tweezers to gently hold the cables and slowly push upward to detach it.
    • Don't be too rough and pinch the cables with the tweezers. Take your time and slowly detach.
  4. LG G Pad 7.0 LTE Front Screen Replacement, Unscrew the motherboard: 步骤 4 中的图像 1,1
    • Remove the 7 black screws on the motherboard.
    • Put them to the side for reassembly.
  5. LG G Pad 7.0 LTE Front Screen Replacement, Detach camera connections from motherboard.: 步骤 5 中的图像 1,3 LG G Pad 7.0 LTE Front Screen Replacement, Detach camera connections from motherboard.: 步骤 5 中的图像 2,3 LG G Pad 7.0 LTE Front Screen Replacement, Detach camera connections from motherboard.: 步骤 5 中的图像 3,3
    • Detach the black tag in the middle of the motherboard. This is the main camera connection.
    • Locate the next camera connection at the top of the motherboard. Disconnect this black tag for your front camera.
    • Now you are able to remove the motherboard from the tablet.
  6. LG G Pad 7.0 LTE Front Screen Replacement, Detach main camera: 步骤 6 中的图像 1,2 LG G Pad 7.0 LTE Front Screen Replacement, Detach main camera: 步骤 6 中的图像 2,2
    • Now that the motherboard is removed, you can now access the main camera for removal. Gently use the tweezers to do this.
    • Put to the side for reassembly.
  7. LG G Pad 7.0 LTE Front Screen Replacement, Remove front speaker: 步骤 7 中的图像 1,2 LG G Pad 7.0 LTE Front Screen Replacement, Remove front speaker: 步骤 7 中的图像 2,2
    • Using the Phillips screwdriver, remove the screw and put aside for reassembly.
  8. LG G Pad 7.0 LTE Front Screen Replacement, Remove orange port strip entirely.: 步骤 8 中的图像 1,3 LG G Pad 7.0 LTE Front Screen Replacement, Remove orange port strip entirely.: 步骤 8 中的图像 2,3 LG G Pad 7.0 LTE Front Screen Replacement, Remove orange port strip entirely.: 步骤 8 中的图像 3,3
    • Two screws are holding the metal plate down. Remove the screws and put aside.
    • Use the tweezers to remove the tape to show the connection.
    • Use the spudger to push up and remove the connection.
    • Use the tweezers to completely remove charging port from tablet. Put aside for reassembly.
  9. LG G Pad 7.0 LTE Front Screen Replacement, Remove battery: 步骤 9 中的图像 1,2 LG G Pad 7.0 LTE Front Screen Replacement, Remove battery: 步骤 9 中的图像 2,2
    • To remove the battery, use the spudger or the Jimmy tool to slowly work your way around the battery.
    • It is being held on by strips of tape so be patient with it. Work it a little bit at a time to remove the battery from the tablet.
    • Put it aside for reassembly.
  10. LG G Pad 7.0 LTE Front Screen Replacement, Remove front screen: 步骤 10 中的图像 1,3 LG G Pad 7.0 LTE Front Screen Replacement, Remove front screen: 步骤 10 中的图像 2,3 LG G Pad 7.0 LTE Front Screen Replacement, Remove front screen: 步骤 10 中的图像 3,3
    • Apply a heat gun or iOpener to front of screen to allow it to warm up the glue.
    • Use opening tool and work your way around the front of the screen. You may have to alternate applying the heat and prying to get it loose enough to separate.
    • Be careful not overdo the heat. Use a low temperature and take your time to separate the screen.
    • Clean the black backing off of any glass still sticking to it. Mine had a lot so I had to scrape for awhile to get all the little pieces off to have a clean surface to apply the new replacement screen.
    • Apply new screen to black backing.
结论
To reassemble your device, follow these instructions in reverse order. You will need new adhesive to apply upon reassembly.
**The time estimate is put at an hour but depending on how much broken glass you are dealing with and having to scrap off old adhesive glue - it could take longer so please have patience when dealing with glass to not injury yourself.
38等其他人完成本指南。
MissHeather
于07/03/15注册
1,674 声望
创作了2篇指南
团队
Android Alliance Android Alliance 的会员
Community
86 名成员
创作了699篇指南
18条评论
Great help..........thanks
James Smith - 回复
Good job but I have just 1 speaker out.
James Smith - 回复
Do you mean you took one speaker out or the speaker is no longer functioning properly?
MissHeather -
Hello Ms. Heather I cannot access the motherboard, I am unable to remove the back cover. Pls help
kmonicaholloway - 回复
Are you using a prying tool and going around the edges of the tablet to open it? What exactly is happening?
MissHeather -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 39,858
