跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
LG G Pad 7.0 Display Assembly Replacement
你所需要的
  1. LG G Pad 7.0 Display Assembly Replacement, Front Panel: 步骤 1 中的图像 1,2 LG G Pad 7.0 Display Assembly Replacement, Front Panel: 步骤 1 中的图像 2,2
    • The screen assembly is secured to the plastic backing with clips.Insert the plastic opening tool between the screen and plastic.
    • Carefully work your way around the device making sure not to go too deep damaging any eternal components, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Display Assembly Replacement, Connectors: 步骤 2 中的图像 1,3 LG G Pad 7.0 Display Assembly Replacement, Connectors: 步骤 2 中的图像 2,3 LG G Pad 7.0 Display Assembly Replacement, Connectors: 步骤 2 中的图像 3,3
    • Remove the red marked connectors by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
    • You will have to remove the metallic tape near the bottom of the tablet to disconnect the display cable.
    • Remove the three connectors marked in orange by gently prying them upwards. The cables are very fragile so be careful not to rip them.
  3. LG G Pad 7.0 Display Assembly Replacement, Logic Board: 步骤 3 中的图像 1,2 LG G Pad 7.0 Display Assembly Replacement, Logic Board: 步骤 3 中的图像 2,2
    • Remove the 7 screws marked in red that are securing the logic board to the case.
    • Be sure that all the connectors marked in orange are removed before pulling out the mother board.
    • Very carefully remove the logic board after the screws have been removed
  4. LG G Pad 7.0 Display Assembly Replacement: 步骤 4 中的图像 1,3 LG G Pad 7.0 Display Assembly Replacement: 步骤 4 中的图像 2,3 LG G Pad 7.0 Display Assembly Replacement: 步骤 4 中的图像 3,3
    • Remove the two screw marked in red.
    • Using the tweezers , gently pull out the metal bracket that holds the charging port in place.
    • Carefully pull out the ribbon connector in orange.
    • Remove the one screw that holds the speaker in place.
    • Slowly pull out the speaker.
  5. LG G Pad 7.0 Display Assembly Replacement: 步骤 5 中的图像 1,2 LG G Pad 7.0 Display Assembly Replacement: 步骤 5 中的图像 2,2
    • Insert your new mother board with the 7 screws
    • Reconnect all the connectors marked in red back to the mother board.
    • Use a heat gun to loosen the adhesive holding the display to the plastic midframe.
    • Slowly remove the display from the midframe with a razor blade.
    • Use double sided tape to adhere the new display to the plastic frame
结论
10等其他人完成本指南。
echow2001
于09/05/15注册
2,117 声望
创作了4篇指南
团队
LGBTQ Technicians LGBTQ Technicians 的会员
Community
14 名成员
创作了23篇指南
6条评论
Thanks so very much for a very helpful guide. YOU rock dude!!!
Tara Davis - 回复
This doesn’t make sense.  guide is to replace display, Step 5 is “Insert new motherboard”???
Then no pictures for steps 6 and 7, are they to be done with motherboard in place or what?
Matt McMains - 回复
What does your replacement display look like? does it include the plastic frame? “New motherboard” incorrectly assumes youre replacing the motherboard, if youre doing a screen, just re insert your old one.
echow2001 -
There should be a different guide for the motherboard. Step 5 is super confusing.
Samuel Enrique Gonzalez - 回复
I totally agree. You should have one guide for just the screen replacement and one for motherboard replacement otherwise anyone following step by step to do either task will be doing unnecessary steps. It would clear up a lot of confusion if there were two separate guides.
Forrest Faulkner - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 4,883
