跳转到主内容
LG G Pad 7.0 Battery Replacement
你所需要的
  1. LG G Pad 7.0 Battery Replacement, Front Panel: 步骤 1 中的图像 1,2 LG G Pad 7.0 Battery Replacement, Front Panel: 步骤 1 中的图像 2,2
    • The screen assembly is secured to the plastic backing with clips. Insert the spudger between the screen and plastic.
    • Work your way around the device, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Attempt to lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Battery Replacement, Battery Connector: 步骤 2 中的图像 1,3 LG G Pad 7.0 Battery Replacement, Battery Connector: 步骤 2 中的图像 2,3 LG G Pad 7.0 Battery Replacement, Battery Connector: 步骤 2 中的图像 3,3
    • Remove the battery connector marked in orange, by prying it upwards.You may need some force to do this, be careful not to damage anything.
    • Remove the other connector marked in red by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
  3. LG G Pad 7.0 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Gently pry the battery up making sure not to bend it or snag any cables.
    • The battery is secured by two pieces of double sided tape on the left and right edges under the battery.
    PERFECT instructions, Thanx.
    Now to find a new battery.
    D.A. Pawley - 回复
结论
18等其他人完成本指南。
echow2001
于09/05/15注册
2,117 声望
创作了4篇指南
团队
LGBTQ Technicians LGBTQ Technicians 的会员
Community
14 名成员
创作了23篇指南
一条评论
Thank you for this guide. The iFixit tool worked much better than the one that came with the replacement battery. I needed a magnifying glass to verify I lined up the ribbon cable connector but other than that it went smoothly.
Juan Campos - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 39
总计 17,341
