跳转到主内容
LG G Pad 7.0 Battery Replacement
你所需要的
  1. LG G Pad 7.0 Battery Replacement, LG G-Pad 7.0: 步骤 1 中的图像 1,1
    • Here it is - LG G-Pad 7.0. Let's dive right in!
  2. LG G Pad 7.0 Battery Replacement, Jumping right into action: 步骤 2 中的图像 1,2 LG G Pad 7.0 Battery Replacement, Jumping right into action: 步骤 2 中的图像 2,2
    • First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
  3. LG G Pad 7.0 Battery Replacement, First Glimpse: 步骤 3 中的图像 1,1
    • Vuala! We're in! Carefully slide the screen assembly away from the back cover.
  4. LG G Pad 7.0 Battery Replacement, A Look on the Inside: 步骤 4 中的图像 1,1
    • Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
  5. LG G Pad 7.0 Battery Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Grab your * Tweezers, the best tweezers you can get!
  6. LG G Pad 7.0 Battery Replacement, Charging Port Flex: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Carefully pry up the charging port connection from the bottom left with your Tweezers.
  7. LG G Pad 7.0 Battery Replacement, Battery Connection: 步骤 7 中的图像 1,1
    • Carefully lift the battery connector.
  8. LG G Pad 7.0 Battery Replacement, Removing the Battery: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    iSesamo Opening Tool
    $9.99
    购买
  9. LG G Pad 7.0 Battery Replacement, Disposal of old Battery: 步骤 9 中的图像 1,1
    • After removing the faulty/dead battery, make sure you properly dispose it.
  10. LG G Pad 7.0 Battery Replacement, Don't Forget!: 步骤 10 中的图像 1,2 LG G Pad 7.0 Battery Replacement, Don't Forget!: 步骤 10 中的图像 2,2
    • After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
    • There you go! A quick battery replacement on your LG G-Pad.
结论
2等其他人完成本指南。
GadgetERService
于11/22/13注册
1,650 声望
创作了2篇指南
团队
Minnesota Repair Techs Minnesota Repair Techs 的会员
Community
3 名成员
创作了2篇指南
2条评论
Big thanks to the Author for this, I used it on my v410, worked perfect !
Max Haxster - 回复
My G pad 7.0 wont turn on. Do I have to do some kind or re-boot or restart it? Cause one time when I changed mi iPhone 5c's battery I had to restart it the phone.
Mario Escobar - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 2,681
