跳转到主内容
LG Front Load Washing Machine Temperature Sensor Replacement
你所需要的
  1. LG Front Load Washing Machine Temperature Sensor Replacement, Safety Precautions: 步骤 1 中的图像 1,2 LG Front Load Washing Machine Temperature Sensor Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the top panel: 步骤 2 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the top panel: 步骤 2 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the top panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Temperature Sensor Replacement, Remove the top panel: 步骤 3 中的图像 1,2 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the top panel: 步骤 3 中的图像 2,2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 4 中的图像 1,2 LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 4 中的图像 2,2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Temperature Sensor Replacement, Remove the detergent drawer: 步骤 5 中的图像 1,2 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the detergent drawer: 步骤 5 中的图像 2,2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 6 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 6 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 6 中的图像 3,3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Temperature Sensor Replacement, Disconnect the control panel: 步骤 7 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Disconnect the control panel: 步骤 7 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Disconnect the control panel: 步骤 7 中的图像 3,3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the control panel: 步骤 8 中的图像 1,2 LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the control panel: 步骤 8 中的图像 2,2
    • Remove the screw(s) securing the control panel to the top edge of the chassis.
  9. LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the detergent dispenser: 步骤 9 中的图像 1,1
    • Remove the screw(s) securing the detergent dispenser.
  10. LG Front Load Washing Machine Temperature Sensor Replacement, Unclip the control panel: 步骤 10 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Unclip the control panel: 步骤 10 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Unclip the control panel: 步骤 10 中的图像 3,3
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
  11. LG Front Load Washing Machine Temperature Sensor Replacement, Remove the control panel: 步骤 11 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the control panel: 步骤 11 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the control panel: 步骤 11 中的图像 3,3
    • Remove the control panel, making sure to thread any cables through the chassis.
  12. LG Front Load Washing Machine Temperature Sensor Replacement, Open the door: 步骤 12 中的图像 1,2 LG Front Load Washing Machine Temperature Sensor Replacement, Open the door: 步骤 12 中的图像 2,2
    • Open the front door completely.
  13. LG Front Load Washing Machine Temperature Sensor Replacement, Remove the boot ring: 步骤 13 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the boot ring: 步骤 13 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the boot ring: 步骤 13 中的图像 3,3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  14. LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 14 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 14 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 14 中的图像 3,3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  15. LG Front Load Washing Machine Temperature Sensor Replacement, Disconnect the boot: 步骤 15 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Disconnect the boot: 步骤 15 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Disconnect the boot: 步骤 15 中的图像 3,3
    • Use your fingers to pull the boot off its lip on the front panel.
  16. LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 16 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 16 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 16 中的图像 3,3
    • Slide your fingers around the lip of the boot until it's completely separated from the panel.
  17. LG Front Load Washing Machine Temperature Sensor Replacement, Remove the filter panel: 步骤 17 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the filter panel: 步骤 17 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the filter panel: 步骤 17 中的图像 3,3
    • Open the filter panel at the bottom of the front panel.
    • Unclip the filter panel.
  18. LG Front Load Washing Machine Temperature Sensor Replacement, Drain the machine: 步骤 18 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Drain the machine: 步骤 18 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Drain the machine: 步骤 18 中的图像 3,3
    • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
    • Place a bowl next to the machine.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  19. LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the filter trim: 步骤 19 中的图像 1,1
    • Remove the screw(s) securing the filter trim.
  20. LG Front Load Washing Machine Temperature Sensor Replacement, Remove the filter trim: 步骤 20 中的图像 1,2 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the filter trim: 步骤 20 中的图像 2,2
    • Pull the filter trim straight off the front panel to remove it.
  21. LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the lower front panel: 步骤 21 中的图像 1,1
    • Remove the screw(s) securing the lower front panel.
  22. LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the door latch: 步骤 22 中的图像 1,1
    • Remove the screw(s) securing the door latch.
  23. LG Front Load Washing Machine Temperature Sensor Replacement, Remove the door latch: 步骤 23 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the door latch: 步骤 23 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the door latch: 步骤 23 中的图像 3,3
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
  24. LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the front panel: 步骤 24 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the front panel: 步骤 24 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Unfasten the front panel: 步骤 24 中的图像 3,3
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Remove the screw(s) securing the front panel.
  25. LG Front Load Washing Machine Temperature Sensor Replacement, Remove the front panel: 步骤 25 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the front panel: 步骤 25 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the front panel: 步骤 25 中的图像 3,3
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
  26. LG Front Load Washing Machine Temperature Sensor Replacement: 步骤 26 中的图像 1,1
    • Remove the front panel.
  27. LG Front Load Washing Machine Temperature Sensor Replacement, Disconnect the temperature sensor: 步骤 27 中的图像 1,2 LG Front Load Washing Machine Temperature Sensor Replacement, Disconnect the temperature sensor: 步骤 27 中的图像 2,2
    • Disconnect the temperature sensor attached to the chassis.
  28. LG Front Load Washing Machine Temperature Sensor Replacement, Cut the cable ties: 步骤 28 中的图像 1,2 LG Front Load Washing Machine Temperature Sensor Replacement, Cut the cable ties: 步骤 28 中的图像 2,2
    • If your device doesn't use cable ties to secure its thermistor, skip this step.
    • Use angle cutters, or scissors, to cut any cable ties securing the temperature sensor to the chassis.
  29. LG Front Load Washing Machine Temperature Sensor Replacement, Remove the temperature sensor: 步骤 29 中的图像 1,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the temperature sensor: 步骤 29 中的图像 2,3 LG Front Load Washing Machine Temperature Sensor Replacement, Remove the temperature sensor: 步骤 29 中的图像 3,3
    • Pull the temperature sensor straight out of its slot in the chassis to remove it.
结论
Repair didn’t go as planned? Ask our Answers community for help.
5等其他人完成本指南。
Bill Gilbert
于06/30/22注册
38,507 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,649篇指南
9指南评论
Awesome thank you
kell kg - 回复
Thank you. the WM2240CW model lower panel screw is a tough fit for a screw driver. I had to tilt the front panel to access the lower panel screw.
Nathan Lee - 回复
Or you could just flip unit on it's side and access it underneath in about 15 minutes....
Kale Martin - 回复
While this is a speedy way to gain access, it is not what LG recommends. (Not that every manufacturer's recommendation is the only way to go, but in this case...) Front-load units have shipping bolts that are supposed to be installed so they can be shipped or moved to a new location. They hold the tub in place so the suspension can't shift in ways it isn't designed to accommodate (on its side is one of those directions). Several potential issues can arise if they aren't in place. Suspension springs can come loose if the spring retainer isn't fully in place. You might also have a hose pull loose from the tub. The suspension dampers aren't meant to bear the load of the tub and drum laterally. The front tub boot may be pulled loose. So, if you choose this access route, strongly consider installing the shipping bolts, tipping the unit to the rear, and securely supporting it from underneath in that position. Since the temperature sensor is on the bottom of the tub, it can be reached this way.
Bill Gilbert -
Nice to see all the steps to pen the front of the machine but it would have been worth mentioning: if you can tip the machine back and secure it at an angle you can access these parts through the open bottom. Without removing a single screw.
Aingle112 - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 90
过去 30 天: 486
总计 8,194
