跳转到主内容
LG Front Load Washing Machine Drain Filter Replacement
  1. LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: 步骤 1 中的图像 1,2 LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: 步骤 1 中的图像 2,2
    • Unclip the filter door from its slot in the chassis and let it rest on the ground.
  2. LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: 步骤 2 中的图像 1,3 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: 步骤 2 中的图像 2,3 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: 步骤 2 中的图像 3,3
    • Place a bowl next to the device.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  3. LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: 步骤 3 中的图像 1,3 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: 步骤 3 中的图像 2,3 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: 步骤 3 中的图像 3,3
    • Twist the drain filter counterclockwise until it's fully disconnected from the chassis.
    • Remove the drain filter.
结论
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
于06/30/22注册
30,088 声望
创作了213篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,420篇指南
一条评论
I need to replace the clip door it fell off when we moved.
Maria Medina - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 25
过去 30 天: 121
总计 1,064
