跳转到主内容
LG Front Load Washing Machine Door Latch Replacement
你所需要的
  1. LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: 步骤 1 中的图像 1,2 LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Door Latch Replacement, Open the door: 步骤 2 中的图像 1,2 LG Front Load Washing Machine Door Latch Replacement, Open the door: 步骤 2 中的图像 2,2
    • Open the front door completely.
  3. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: 步骤 3 中的图像 1,3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: 步骤 3 中的图像 2,3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: 步骤 3 中的图像 3,3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  4. LG Front Load Washing Machine Door Latch Replacement: 步骤 4 中的图像 1,3 LG Front Load Washing Machine Door Latch Replacement: 步骤 4 中的图像 2,3 LG Front Load Washing Machine Door Latch Replacement: 步骤 4 中的图像 3,3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  5. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: 步骤 5 中的图像 1,3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: 步骤 5 中的图像 2,3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: 步骤 5 中的图像 3,3
    • Use your fingers to pull the boot off its lip in the front panel.
  6. LG Front Load Washing Machine Door Latch Replacement: 步骤 6 中的图像 1,3 LG Front Load Washing Machine Door Latch Replacement: 步骤 6 中的图像 2,3 LG Front Load Washing Machine Door Latch Replacement: 步骤 6 中的图像 3,3
    • Work your fingers around the boot's perimeter until it's completely separated from the panel.
  7. LG Front Load Washing Machine Door Latch Replacement: 步骤 7 中的图像 1,2 LG Front Load Washing Machine Door Latch Replacement: 步骤 7 中的图像 2,2
    • Use your hands to fold the boot into the drum.
  8. LG Front Load Washing Machine Door Latch Replacement, Unfasten the door latch: 步骤 8 中的图像 1,1
    • Remove the screw(s) securing the door latch.
  9. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: 步骤 9 中的图像 1,3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: 步骤 9 中的图像 2,3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: 步骤 9 中的图像 3,3
    • Reach between the boot and the chassis to grip the door latch.
    • Pull the door latch out of its slot in the chassis to expose it.
    • Don't try to fully remove the door latch yet. It's still connected to a cable harness.
  10. LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: 步骤 10 中的图像 1,2 LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: 步骤 10 中的图像 2,2
    • Disconnect the cable harness from the door latch.
    • Always grip cables by their connectors and not the wires themselves.
    • Remove the door latch.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
Bill Gilbert
于06/30/22注册
38,500 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,644篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 72
过去 30 天: 259
总计 8,582
