简介
Use this guide to replace the detergent dispenser in your LG front load washing machine.
The detergent dispenser houses the detergent drawer. It has no moving parts and is unlikely to break.
This guide will work for most LG front-load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
你所需要的
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Remove the screw(s) securing the top panel brackets to the back panel.
Slide the top panel towards the rear of the device to disconnect its clips.
Pull the detergent drawer away from the chassis as far as it will go.
Unclip any connections the control panel cable has to the chassis or other components.
To prevent confusion, label each detergent hose and its corresponding dispenser connection.
Loosen any fasteners securing the bellows to the detergent dispenser.
Pull the bellows straight off its connection on the dispenser to disconnect it.
Slide the detergent dispenser out of its slot in the chassis to unclip it.
Completely separate the dispenser from the chassis.
Repair didn’t go as planned? Ask our Answers community for help.
