跳转到主内容
LG Front Load Washing Machine Detergent Bellows Replacement
你所需要的
  1. LG Front Load Washing Machine Detergent Bellows Replacement, Safety Precautions: 步骤 1 中的图像 1,2 LG Front Load Washing Machine Detergent Bellows Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Detergent Bellows Replacement, Unfasten the top panel: 步骤 2 中的图像 1,3 LG Front Load Washing Machine Detergent Bellows Replacement, Unfasten the top panel: 步骤 2 中的图像 2,3 LG Front Load Washing Machine Detergent Bellows Replacement, Unfasten the top panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Detergent Bellows Replacement, Remove the top panel: 步骤 3 中的图像 1,2 LG Front Load Washing Machine Detergent Bellows Replacement, Remove the top panel: 步骤 3 中的图像 2,2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Detergent Bellows Replacement: 步骤 4 中的图像 1,2 LG Front Load Washing Machine Detergent Bellows Replacement: 步骤 4 中的图像 2,2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the control panel: 步骤 5 中的图像 1,3 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the control panel: 步骤 5 中的图像 2,3 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the control panel: 步骤 5 中的图像 3,3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG Front Load Washing Machine Detergent Bellows Replacement, Unclip the control panel cable: 步骤 6 中的图像 1,3 LG Front Load Washing Machine Detergent Bellows Replacement, Unclip the control panel cable: 步骤 6 中的图像 2,3 LG Front Load Washing Machine Detergent Bellows Replacement, Unclip the control panel cable: 步骤 6 中的图像 3,3
    • Unclip any connections the control panel cable has to the chassis or other components.
  7. LG Front Load Washing Machine Detergent Bellows Replacement, Detergent dispenser hose information: 步骤 7 中的图像 1,1
    • To prevent confusion, label each detergent hose and its corresponding dispenser connection.
    • You can use masking tape or mark the components themselves.
  8. LG Front Load Washing Machine Detergent Bellows Replacement: 步骤 8 中的图像 1,2 LG Front Load Washing Machine Detergent Bellows Replacement: 步骤 8 中的图像 2,2
    • Use slip joint pliers to pinch the detergent dispenser hose clamp and pull it away from the assembly.
  9. LG Front Load Washing Machine Detergent Bellows Replacement: 步骤 9 中的图像 1,2 LG Front Load Washing Machine Detergent Bellows Replacement: 步骤 9 中的图像 2,2
    • Use slip joint pliers to gently rotate the detergent dispenser hose back and forth around its connection and loosen it.
  10. LG Front Load Washing Machine Detergent Bellows Replacement: 步骤 10 中的图像 1,2 LG Front Load Washing Machine Detergent Bellows Replacement: 步骤 10 中的图像 2,2
    • Pull the detergent dispenser hose straight off its connection on the assembly.
    • Repeat the loosening and removal procedure for each hose.
  11. LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the dispenser: 步骤 11 中的图像 1,3 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the dispenser: 步骤 11 中的图像 2,3 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the dispenser: 步骤 11 中的图像 3,3
    • Loosen any fasteners securing the bellows to the detergent dispenser.
    • Pull the bellows straight off its connection on the dispenser to disconnect it.
  12. LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the bellows: 步骤 12 中的图像 1,3 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the bellows: 步骤 12 中的图像 2,3 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the bellows: 步骤 12 中的图像 3,3
    • Loosen the fastener securing the bellows to the drum.
    • Pull the bellows straight up from the drum to disconnect it.
  13. LG Front Load Washing Machine Detergent Bellows Replacement, Remove the bellows: 步骤 13 中的图像 1,1
    • You're now left with the bellows.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
Bill Gilbert
于06/30/22注册
38,500 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,638篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 61
总计 758
