跳转到主内容
LG Front Load Washing Machine Control Panel Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: 步骤 1 中的图像 1,2 LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: 步骤 2 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: 步骤 2 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: 步骤 3 中的图像 1,2 LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: 步骤 3 中的图像 2,2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Control Panel Replacement: 步骤 4 中的图像 1,2 LG Front Load Washing Machine Control Panel Replacement: 步骤 4 中的图像 2,2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: 步骤 5 中的图像 1,2 LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: 步骤 5 中的图像 2,2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Control Panel Replacement: 步骤 6 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement: 步骤 6 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement: 步骤 6 中的图像 3,3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: 步骤 7 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: 步骤 7 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: 步骤 7 中的图像 3,3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: 步骤 8 中的图像 1,2 LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: 步骤 8 中的图像 2,2
    • Remove the screw(s) securing the control panel to the top edge of the chassis.
  9. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: 步骤 9 中的图像 1,1
    • Remove the screw(s) securing the detergent dispenser.
  10. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: 步骤 10 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: 步骤 10 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: 步骤 10 中的图像 3,3
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
  11. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: 步骤 11 中的图像 1,3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: 步骤 11 中的图像 2,3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: 步骤 11 中的图像 3,3
    • Remove the control panel, making sure to thread any cables through the chassis.
结论
Bill Gilbert
于06/30/22注册
38,507 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,649篇指南
1指南评论
other than replacing the control panel is there ways to repair the machine which just dont switch on
ratseaneboy@gmail.com - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 82
